Hello Guest it is October 24, 2026, 02:46:14 AM
Author Topic: Ports & Pins gets reset automatically  (Read 10884 times)
Chuck
« on: April 14, 2007, 09:14:05 PM »
the X-Alis "Step Pin#" in the "Motor Outputs" tab gets set to some random pin number everytime.
I have to manually set it back to 2 everytime and after some time, it gets set back to some other random pin number.
Any idea what causes this and how can I prevent it from happening again?
Thanks in advance.
Re: Ports & Pins gets reset automatically
« Reply #1 on: April 15, 2007, 02:23:49 AM »
Try changing it to the correct number then saving and exiting  restarting Mach. Other thing to look for is make sure you dont have any other output set for that pin, not sure if that would do it but....
« Reply #2 on: April 15, 2007, 11:46:12 AM »
I think you need to download the newest Rev of Mach3 and that should fix the problem :)
Brian
www.newfangledsolutions.com
www.machsupport.com
