Hello Guest it is November 13, 2026, 01:02:28 PM
Author Topic: Using Drawings and Cam programs on a computer running Mach 3  (Read 11881 times)
I am building a new CNC router, transitioning from linuxcnc to Mach 3.  I will be driving the router  via an ethernet smoothstepper. With my current small router I do all of the cad/cam in the office and then send it via a shared folder to the PC controlling the machine.  Would there be any issue using a single computer to do both, or is this generally seen as a poor practice?   There are times when I would I am iterating the design for a few a simple component rapidly, It involves making changes quickly and doing test cuts,  Say making a new cut every 10 minutes, switching computers has been a real hassle.
Thanks!
Offline dude1
  •  1,253 1,253
Re: Using Drawings and Cam programs on a computer running Mach 3
« Reply #1 on: March 10, 2015, 01:48:11 AM »
it pays not to some computers cant handle M3 very well and having a cad program running at the same time can make it worse I have tried it and it was a bad idea on both my machines
« Reply #2 on: March 10, 2015, 03:33:59 AM »
No problems with having CAD, CAM, and other programs installed on the computer.
Just don't use the programs if you are running Mach.
Offline dude1
  •  1,253 1,253
« Reply #3 on: March 10, 2015, 03:54:25 AM »
take what rich said over what I said it was my computers yours my be diffrent
« Reply #4 on: March 11, 2015, 04:32:01 PM »
You could link the cnc computer with the design pc via file sharing. Just drag and drop the file to the cnc pc. I use that option and it work great. Personally I have found its best to keep the cnc pc just running mach. There was a Youtube video of some guy running mach 3 and checking his email at the same time on a laptop.... he closed the email window and the tool bit crashed into the work. Priceless.
« Last Edit: March 11, 2015, 04:34:11 PM by geh7552 »
« Reply #5 on: March 11, 2015, 07:03:16 PM »
I run CamBam at the same time as Mach3 with no problem, BUT I do have a motion card driving the motors and I think that would be the difference. It is really really nice to have the Cam program and Alt Tab away from the CNC and you can make a change and repost in a few seconds.  Mach3 remembers the last file you loaded from too.
« Reply #6 on: March 11, 2015, 09:48:59 PM »
If you're not running the machine while using the programs, then there's no problem at all. Depending on the specs of your computer, you may be able to do both.
