Hello Guest it is November 13, 2026, 02:17:12 PM
Author Topic: Axis Calibration Trouble from a Newbie!  (Read 7956 times)
« on: March 09, 2015, 02:25:11 PM »
I am very new to the CNC world. My machine seems to be running well and accurate but I can't seem to get the Z axis to cut the proper depth. X & Y seem fine as far as accuracy but Im not sure what to try next. I have tried calibrating in Mach through the Set steps per unit tab in settings but every time that I do this it sets the steps per unit way higher than my motors can handle. They just hum really loud and don't move. Could this be a file issue rather than a Mach setting issue? Thanks!
I am using VCarvePro to set up my G Code files.
Re: Axis Calibration Trouble from a Newbie!
« Reply #1 on: March 09, 2015, 03:19:48 PM »
I assume you are doing it correctly.
Then
You should go back and tune the motors / change the values for proper velocity and acceleration.
You should also have a look at the Mach manual and video's,
