Hello Guest it is November 13, 2026, 09:41:18 AM
Author Topic: Toggle output from button input?  (Read 55934 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Toggle output from button input?
« Reply #30 on: March 10, 2015, 05:51:54 AM »
i am not a friend of the macropump road.
can i get you into my OEMTRIGGER road as described in my small tutorial (PDF) ?
Hi Thomas
Unfortunately trigger macros have been "damaged" for many years. Your scheme as described (in your PDF) will work fine as long as Mach's not doing anything else but try triggering your macro whilst some gcode is running. I think you'll be disappointed. :'(
I tried for years to get this fixed but to no avail.
Ian
Offline TPS
  •  2,627 2,627
« Reply #31 on: March 10, 2015, 06:07:41 AM »
Hello Ian,
thank you for this information, never tryed this.
So the only possibilities during running the machine will be
macropump and brain (but brains are also courious sometimes).
Thomas
Offline stirling
  •  2,188 2,188
  • UK
« Reply #32 on: March 10, 2015, 06:54:37 AM »
indeed (note that OEM triggers are fine - they fire immediately - it's just trigger MACROS that have the "turned up late for work" problem).
Offline TPS
  •  2,627 2,627
« Reply #33 on: March 10, 2015, 07:28:00 AM »
Hello Ian,
sorry my english is to bad to translate ("turned up late for work" problem) this correctly, could you please explain ?
Thank You Thomas
Offline stirling
  •  2,188 2,188
  • UK
« Reply #34 on: March 10, 2015, 09:56:30 AM »
Sorry Thomas - I just meant to say that the problem is that the macro runs late i.e. after any gcode buffer is emptied rather than when the trigger actually fires.
Ian
Offline TPS
  •  2,627 2,627
« Reply #35 on: March 10, 2015, 10:03:54 AM »
ok got it now.
Thomas
« Reply #36 on: May 27, 2015, 01:55:05 AM »
hello hood,
as you know all Digital outputs are turned off as soon as  E-stop or Emergency Button or limit Switch is trigged.
i have 2 horizontal Routers that travill Up/Down by a Penumatic Piston controlled by 2 Digital outputs.
and if they were in working in and i press the e stop or any Limit Switch been trigged the piston will go up and damage the Wooden workPiece or breake the tool.
so how i can avoid this problem that these digital outputs not turned off if the E-Stop is trigged or any emergency button is pressed??
please let me know!
regards;
Ghantos
Offline TPS
  •  2,627 2,627
« Reply #37 on: May 27, 2015, 06:36:15 AM »
Change the valves to 5/2 pulse triggered (4 Outputs).
than the valve stayes in his last Position.
Tomas
« Last Edit: May 27, 2015, 06:39:27 AM by TPS »
« Reply #38 on: May 27, 2015, 07:05:46 AM »
Dear Tomas,
thank you for the answer.
by the way i know this solution but the problem that i have no more Outputs to use!
i ask if there is any logic condition or to wirte a macro for this.
please let me know!
regards;
Ghantos
Offline TPS
  •  2,627 2,627
« Reply #39 on: May 27, 2015, 08:02:06 AM »
dont think there is a macro solution, bcause the Outputs will be turned off anyway.
may be you can use a Hardware filp-flop relay (1st puls on, next pulse off and so on)?
Thomas
