Hello Guest it is November 13, 2026, 12:18:11 PM
Author Topic: Toggle output from button input?  (Read 55961 times)
Re: Toggle output from button input?
« Reply #10 on: March 09, 2015, 09:33:54 AM »
Thanks for your help guys, maybe I'm doing something wrong but no joy I'm afraid. Maybe I'll just do it outside of Mach 3.
I was hoping just to copy the routine that's used for the Flood Toggle and Mist Toggle buttons on the Diagnostic screen, both of which I have operated from external buttons. I'm clearly missing something basic.
Offline TPS
  •  2,627 2,627
« Reply #11 on: March 09, 2015, 09:38:49 AM »
Have you macropump enabled in general config ?
is your macropump macro in the wright folder ?
is your input1 working in diagnostic screen ?
« Reply #12 on: March 09, 2015, 09:52:00 AM »
Have you macropump enabled in general config ? Yes
is your macropump macro in the wright folder ? Yes
is your input1 working in diagnostic screen ? No
Where's the drowning man emoticon, I think I'm way out of my depth here!
« Reply #13 on: March 09, 2015, 09:58:04 AM »
I think I'm getting very confused here, Do I just enter the macro as this
If not IsActive (Input1)  = True Then
  LED = GetOEMLED(78)  ' LED looks at state of Output 5 LED
End If
If IsActive (Input1) And LED = True Then  ' looking at input 1 and LED of Output 5
  DeActivateSignal (OutPut5)
Else
 If IsActive (Input1) And LED = False Then
 End If
End If
Or do I follow the guide in the pdf attached to Thomas's post???
« Reply #14 on: March 09, 2015, 10:09:07 AM »
That should work as above.
Remember you need to restart Mach any time you alter the macropump.
Is Input 1 working yet when you press your switch?
« Reply #15 on: March 09, 2015, 10:17:51 AM »
Ok, have re-entered as above, input 1 is operating in diagnostics but not triggering output 5?
« Reply #16 on: March 09, 2015, 10:22:14 AM »
Does output 5 LED light on diagnostics?
« Reply #17 on: March 09, 2015, 10:33:26 AM »
Does output 5 LED light on diagnostics? No!
If I step through the macro in debug mode with no input to input 1 nothing happens, with input 1 on when I get to the 2nd last EndIf then output 5 turns on but stays on irrespective of input 1 status. only reset seems to clear it.?
« Reply #18 on: March 09, 2015, 10:38:38 AM »
Is your switch a momentary switch?
« Reply #19 on: March 09, 2015, 10:41:38 AM »
Is your switch a momentary switch?.............. Yes
