Hello Guest it is November 22, 2026, 03:14:40 PM
Author Topic: Trouble Getting Started  (Read 26003 times)
Re: Trouble Getting Started
« Reply #10 on: April 13, 2007, 02:26:03 PM »
The motor will not jog.  The X axis on screen position does change, but the motor is not responding.
« Reply #11 on: April 13, 2007, 02:30:06 PM »
I also notice you have Enable 1 set for port 1 and Pin 0, do you need the enable for your drives if so then you will have to set the correct pin.
 Also did you try changing the Dir/step  active state like chip suggested earlier?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #12 on: April 14, 2007, 10:17:54 PM »
Hi, DirtyBird
Give this XML a try, Turned on Jog On/Off, (Hood), Changed Dir/step  LowActive state to "Checked".
Hope this gets It, Chip
« Reply #13 on: April 17, 2007, 06:07:14 PM »
Well. I figured out what the problem was.  The pulse lengths for the Step and Directions were too low.  The stepper driver board is opto-isolated, so I guess that the pulses need to be longer to get the signals to the motors.  Everything is working fine now!!  Is there a way to make the pulses longer than 25 us??
Thanks for everyone's help and suggestions on this sticky situation!!  GO MACH3!
« Reply #14 on: April 17, 2007, 06:13:50 PM »
Have you tried Sherline mode? I am sure this is meant for drives that need increased pulse time.
