Hello
Guest
it is
November 23, 2026, 09:13:25 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Machine configuration file
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Machine configuration file (Read 10090 times)
pminmo
7
on:
April 12, 2007, 02:26:53 PM »
If you want to move a machine to another computer, is there a file that has the machine definition that needs to be copied, or do you have to set it up all over again?
Logged
Brian Barker
3,860
Re: Machine configuration file
Reply #1 on:
April 12, 2007, 03:03:34 PM »
you need to move over you XML file. Most use the Mach3Mill.xml
thanks
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Reply #2 on:
April 12, 2007, 05:17:24 PM »
Also make sure you copy your Mach1Lic.dat and if you use keygrabber or have a custom screen or custom macros you will need to save them.
Logged
Print
Pages:
1
Go Up
« previous
next »
