Hello Guest it is November 13, 2026, 09:38:45 AM
Author Topic: Parallel Port ID - Help Please  (Read 12223 times)
« on: March 07, 2015, 05:38:58 AM »
Hi Everyone,
Could someone confirm which Parallel Port ID number I should use?
my address path is:     Device Manager / Ports / PCI ECP Parallel Port (LPT3)
                                             PCI ECP Parallel Port (LPT3) / properties  /  resources.
In the resource window I have TWO   I/O ranges  and TWO memory ranges listed.
My I/O ranges are:  CCF0 - CCF7
                           CCF8 - CCFF
Should I be entering CCF0 as my Parallel Port ID?
Many Thanks
  •  9,377 9,377
Re: Parallel Port ID - Help Please
« Reply #1 on: March 07, 2015, 05:46:04 AM »
Correct.
« Reply #2 on: March 07, 2015, 08:33:43 AM »
Many Thanks for the Quick reply.
"Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill."
I do hope your right ........................... because I lost my enthusiasm months ago!
cheers
  •  9,377 9,377
« Reply #3 on: March 07, 2015, 09:35:42 AM »
Never loose enthusiasm my friend - it will all be worth the effort, in the end.  ;)
« Reply #4 on: March 07, 2015, 12:21:39 PM »
Hi Tweakie,
thanks for the reply.  Can I ask in my original post above.......... my Device Manager description detects my Parallel Port as (LPT3) CCF0
does this mean that ALL my port references in Darwin and Mach 4 should be set to PORT 3 ?
John
  •  9,377 9,377
« Reply #5 on: March 08, 2015, 01:01:54 AM »
Hi Tweakie,
John
No, that is just the PC's identification. In Mach3 & Mach4 you use (or rather set everything up as) Port 1.
« Reply #6 on: March 09, 2015, 12:41:44 PM »
Hi Tweakie,
Many Thanks for your Help and Advice
John
