Hello Guest it is November 27, 2026, 05:16:25 PM
Author Topic: USB or other Port  (Read 7756 times)
USB or other Port
« on: March 06, 2015, 04:07:12 PM »
When, if ever, will Mach make it possible to use any port other then the printer port????
USB or other Port
« Reply #1 on: March 06, 2015, 04:38:40 PM »
For what?  Only the parallel port gives enough i/o from a PC with good enough control over the signal timing to drive steppers accurately.  The trend now is to remove parallel ports from new PCs so they have to use either Ethernet or USB but these don't give control over relative timing on multiple hardware channels so you need an external motion controller.
Sent from my iPad using Tapatalk
