Hello Guest it is November 13, 2026, 09:44:29 AM
Author Topic: Newbie Issues  (Read 11987 times)
Offline Kammo
  •  11 11
Newbie Issues
« on: March 06, 2015, 07:27:01 AM »
 Ok not sure if this is the correct place for this post and sorry if its not, but here goes.
New to this but am having issues getting the .TAP file to show up correctly in Mach3.
I created a file with Cut2D, sent it to LazyCam, set all the values needed and posted it to Mach3.
In Mach3 it is super big and 95% of the image doesn't even show on the image display.
 What am I doing wrong?
I am adding the lazycam file, if you can fix it or tell me what I did wrong I would greatly appreciate it!!
 I am using a 0.050" DIAMOND CUT CARBIDE ROUTER BURR
 Cutting 30"x20" 3/16 thick dollar tree foam board
Any help would be great
Thank you!
Re: Newbie Issues
« Reply #1 on: March 06, 2015, 07:54:47 AM »
Why are you sending the Cut2D file to LazyCAM? Create your g-code in Cut2D.
Offline Kammo
  •  11 11
Re: Newbie Issues
« Reply #2 on: March 06, 2015, 08:24:28 PM »
Well the Cut2D only saves files to DXF, EPS & AI formats. Mach3 wont read any of those, only TAP, NC, NCC & TXT..
LazyCam exports to TAP.
Re: Newbie Issues
« Reply #3 on: March 06, 2015, 08:37:47 PM »
You need to learn how to use Cut2D.
Create your toolpaths in Cut2D, then use the Save Toolpath option to export your g-code from Cut2D.
There's no reason for you to be using LazyCAM.
Offline Kammo
  •  11 11
Re: Newbie Issues
« Reply #4 on: March 06, 2015, 08:44:17 PM »
DUDE!! You're the bomb! I didn't even know that was there....
 Would you recommend a tutorial that I should watch on how to use Cut2D?
Re: Newbie Issues
« Reply #5 on: March 06, 2015, 08:48:18 PM »
Offline Kammo
  •  11 11
Re: Newbie Issues
« Reply #6 on: March 06, 2015, 10:02:26 PM »
OH AWESOME!!! Thank you very much ger21 for your help!!!!
