Hello Guest it is November 13, 2026, 02:15:25 PM
Author Topic: External LED's Again  (Read 9051 times)
« on: March 05, 2015, 03:31:03 AM »
Sorry about this, I' sure it must have been covered but I've done a search and gained some info but am still not sure how to achieve what I want.
I am trying to drive 2 external led's to duplicate the Flood and Mist Led's in Mach 3. The OEM codes are 12 and 13 for these Led's
From another post I've gathered the following Macro will do what I want if I assign Output 8 to an output pin connected to my Flood led.
If GetOEMLED (12) Then
ActivateSignal (Output 8)
End If
Have I got this exactly right? and if so where/how do I enter and save the Macro
Many thanks, I'm nearly there now!
Re: External LED's Again
« Reply #1 on: March 05, 2015, 03:41:45 AM »
Would also likely need an Else,
If GetOemLED(12) Then
ActivateSignal (OutPut 8 )
Else
DeActivateSignal(OutPut 8 )
End If
You would write it in the macropump so that it is always running in the background. You would have to enable the macropump in General Config and then restart Mach for it to be loaded.
If you do not already have a macropump just save the above code and name it macropump.m1s and save to the macro folder of the profile you are using.
Alternatively you could use a Brain.
« Reply #2 on: March 05, 2015, 04:13:15 AM »
Many thanks, all sorted!
