Hello Guest it is November 14, 2026, 12:21:12 AM
Author Topic: AutoZ Issue  (Read 11816 times)
AutoZ Issue
« on: February 21, 2015, 07:16:11 PM »
Auto Z was working just fine. Now it will not work properly. When I click on my auto z button the bit comes down about 1/8" then pulls up the the retract distance and says that Z is Zeroed. But it is not. I have tried redoing the script using a completely different script same issue. I have rebooted and restarted everything does it every time. Any suggestions?
Re: AutoZ Issue
« Reply #1 on: February 21, 2015, 10:00:19 PM »
Possibly noise triggering the input.
Re: AutoZ Issue
« Reply #2 on: February 21, 2015, 10:07:25 PM »
How DO I filter out noise if that is what it is? Or find out if it is noise?
Offline dude1
  •  1,253 1,253
Re: AutoZ Issue
« Reply #3 on: February 21, 2015, 10:15:03 PM »
one way to find noise is with a radio on fm have it tuned into a station stick it on the machine and if it goes all statistic you have noise that's a ruff way to do it it works thoe,
also inspect all the wiring you could have a bad wire.
there are lots of things that can make noise happen those two things are quick checks
Re: AutoZ Issue
« Reply #4 on: February 21, 2015, 10:16:33 PM »
A lot of people add a capacitor across the input.
Re: AutoZ Issue
« Reply #5 on: February 22, 2015, 01:22:38 PM »
Thanks for  info. The cap across the input did the trick.
