Hello Guest it is October 24, 2026, 05:28:24 PM
Author Topic: Mach4 plugin  (Read 19226 times)
Mach4 plugin
« on: February 21, 2015, 02:03:33 PM »
Will Mach4 parallel port plugin work with Mach3 on a win8 64 bit desktop PC. Thank you Art Mancini
Re: Mach4 plugin
« Reply #1 on: February 21, 2015, 02:21:03 PM »
No.
Nothing for Mach4 will work with mach3, and you can't use the parallel port with a 64 bit OS.
Re: Mach4 plugin
« Reply #2 on: February 21, 2015, 03:12:22 PM »
Even mach4 on 64 bit with the plugin.
Re: Mach4 plugin
« Reply #3 on: February 21, 2015, 03:16:58 PM »
Nope
Re: Mach4 plugin
« Reply #4 on: February 22, 2015, 06:06:28 PM »
Unless.........
You retrofit it with an Allen-Bradley Retro-Encabulator, di-phazent worberler shaft, and a Kanooter Valve! THEN, you should be good....
I mean, "What could POSSIBLY go wrong?"
Scott
Offline dude1
  •  1,253 1,253
Re: Mach4 plugin
« Reply #5 on: February 22, 2015, 09:50:49 PM »
what ever that is
Re: Mach4 plugin
« Reply #6 on: February 22, 2015, 10:25:10 PM »
https://www.youtube.com/watch?v=RXJKdh1KZ0w
And don't let Scott fool ya you cannot use a  di-phazent worberler shaft with a a Kanooter Valve. It will ONLY work with a tri-phazent worberler shaft. If you tried the former you WILL get a turbulent phase imbalance that WILL wreck the Kanooter valve every time.
Offline dude1
  •  1,253 1,253
Re: Mach4 plugin
« Reply #7 on: February 22, 2015, 10:35:24 PM »
is that real, that's some wear words he used
Re: Mach4 plugin
« Reply #8 on: February 23, 2015, 07:21:23 AM »
Yes, some of what Terry said is true, his video link is THE place to learn this stuff!!
And Terry:
Just so you know, if the reluctance capacitance of the Flux Capacitor is set
to demodulate at a Wietzfelt harmonic of 1.2 GW, then you can use a di-phazent worberler
shaft with a Kanooter Valve! So....... HA.......... Take that you PIKER!!  :)
and to daniellyall:
Of course its true, it is like the IRS saying, "We are with the Gov., and we are here to help you!"
If you can trust that, then you can trust what Terry and I are saying!
Scott
Re: Mach4 plugin
« Reply #9 on: February 23, 2015, 12:19:26 PM »
Come on now Scott EVERYONE knows that if you demodulate a  di-phazent worberler at more than .0001W much less 1.2GW. The resulting instability will decrystalize the bilateral frequency of the shaft. The results being a broken Kanooter valve. Ya need to be in the field more WORKING on these Encabulators  rather than just staying in the shop eating doughnuts and studying Cabulator THEORY. IF you can't grasp Encabulator theory you will NEVER get Retro-Encabulator theory.
Here we do NOT go on the Gov's word of trust me.
It is "In GOD We Trust" all others CASH
AND IF it is on the internet it MUST be TRUE.
AND that is a fact Jack, (;-) TP
« Last Edit: February 23, 2015, 12:23:31 PM by BR549 »
