Hello Guest it is October 04, 2026, 11:54:35 PM
Author Topic: G19 and G68 at same time  (Read 13087 times)
« on: April 10, 2007, 10:28:55 PM »
Hello, i've got a circle and need to carve out some notches, but I'd like to feather the edges with vertical arcs in the YZ azis (selecting G19).  To make the Gcode easy, i've created one set of commands and just copy them using a different coordinate rotation (G68) for each cut.
Unfortunately, it seems that Axis rotation can only occur when in the G17 (XY plane) mode.  Does anyone know of a workaround that might do the same thing?  Will concurrent G19 and G68 be available in a future release?
   Stewart
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G19 and G68 at same time
« Reply #1 on: April 11, 2007, 02:54:49 AM »
Have you got a rotary axis, if so put it on its back and use that to do the rotation.
Graham
« Reply #2 on: April 12, 2007, 10:28:02 AM »
Man, you guys think of stuff that we never think of!
Could you please pst a small sample of what you are looking to do?
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
