Hello Guest it is October 15, 2026, 10:31:34 PM
Author Topic: Slave axis is not moving on G-code  (Read 9086 times)
« on: February 16, 2015, 07:11:34 PM »
Hello All,
I am new to the forum and i will thank everyone in advance for help with this question.
I am running Mach 3 with a breakout board (PBX-RF rev 4.1) and 2m542-06 controllers. my OP system is windows XP W/ service pack3.
everything works in my setup and i have A slaved to my Y axis.  A&Y work together when i jog the Y axis. they all home properly
BUT when i load the G-code and it runs only the Y axis moves! Z,X AND THE SPINDLE WORK BUT the A wont move when running the code.
any help would be great.
thank you.....Adam
Re: Slave axis is not moving on G-code
« Reply #1 on: February 18, 2015, 05:58:11 AM »
Attach your xml and the problem code and someone will see if they can find an issue.
« Reply #2 on: December 20, 2015, 03:01:04 PM »
Hi!
Find software my new project, but i have in Mach3 same issue.
Loading sample G-code and it runs only the Y axis moves, slave A not moving at all?In jogging mode Y and A moves together nicely.
Using  breakout board (STB4100) and ST-40-45-A1 controllers.
All best,
Priit
