Hello Guest it is November 24, 2026, 07:02:54 AM
Author Topic: Mach4 or Mach3  (Read 10976 times)
Mach4 or Mach3
« on: February 16, 2015, 01:37:31 PM »
Ok guys, looking for some advice but first a little background.
I have purchased my X2 mini mill, installed my CNC Fusion conversion and have a Windows 7 machine running Mach3 which can successfully "jog" the table and spindle accordingly through a PCI-E based parallel port. I have no background in CNC work but have spent a fair amount of time looking through G-Code examples and feel extremely comfortable bridging the gap between G-Code and the actual machine movements (my day job is as a Java programmer). I have not purchased Mach3 or 4 as of now. Now for my 2 basic questions...
First, should I stick with Mach3 or start out of the gate with Mach4? From reading the literature on both, I take it that to use the existing parallel port config I have, I need a legacy Mach3 license but the cost is not the issue. I would purchase both if necessary but which to start with?
The second question is, is LazyCam sufficient to import simple 2x3 inch graphics and create correlating G-Code for engraving?
Sig
Re: Mach4 or Mach3
« Reply #1 on: February 16, 2015, 05:43:07 PM »
I would start with Mach3.
Lazycam works with  DXF files not image files ( if that is what you mean by graphics).
There are simple programs that one can use for creating gcodes from text. May wan to look at the current Wizard MAch provides.
« Last Edit: February 16, 2015, 05:44:40 PM by RICH »
Re: Mach4 or Mach3
« Reply #2 on: February 16, 2015, 07:13:22 PM »
Thanks for the reply.
Seems if I do go with Mach4, I simply need to purchase the Darwin plugin for my parallel port. Since I can find no place to download Darwin, does it come with the Mach4 Hobby version?
Sig
Re: Mach4 or Mach3
« Reply #3 on: February 16, 2015, 07:17:12 PM »
Re: Mach4 or Mach3
« Reply #4 on: February 16, 2015, 08:20:31 PM »
Thanks so much. Totally overlooked that download. Sorry...
Sig
