Hello Guest it is November 13, 2026, 05:11:36 PM
Author Topic: pokeys+cncaddon when Estop is pressed motors are feed  (Read 11511 times)
« on: February 15, 2015, 04:49:48 PM »
Hello,
I'm configuring a new electronic box for my cnc and I use pokeys57U and a CNCAddon.
When I press the E-stop or limits all stops immediately, (the E-stop is configured on a pin 24 of pokeys and Input I/O E-stop configured) but the motors are still feeded and enabled.
I need that when I stop the CNC the motors have to be not feeded and enabled, because sometime I leave it stopped for several time, and motors are very hot.
The last B.B. with parallel port do it, but I'm not able to configure this in pokeys and pulse engine.
How i can do it?
thanks
Offline NeoTO
  •  504 504
    • PoLabs
Re: pokeys+cncaddon when Estop is pressed motors are feed
« Reply #1 on: February 15, 2015, 11:22:14 PM »
Hi, Claudio
As we replied to your question on our support e-mail, let us know of which PoKeys firmware version are you running? The bug should have been fixed in of the updates a while ago.
Matevž
« Reply #2 on: February 18, 2015, 02:04:14 AM »
Thanks NeoTo, was the old plugin the problem, thanks a lot for your patience
