Hello Guest it is November 13, 2026, 01:54:03 PM
Author Topic: Safer connection from Mach3 to X200 VFD?  (Read 45945 times)
Re: Safer connection from Mach3 to X200 VFD?
« Reply #30 on: February 20, 2015, 07:19:50 AM »
I use stop--> Run from Here --> Start all the time... never an issue. If you use Stop and then Start (not using "Run from here" before the start) you will lose some position.
