Hello Guest it is November 26, 2026, 01:47:41 PM
Author Topic: Ref all home dont move motors  (Read 10827 times)
« on: February 06, 2015, 06:40:04 AM »
Im new to Mach3 so sorry if my question is stupid.
I buy chinese router with USB XHC driver.
Endstops working great If i press switch a see lights in diagnostics page. Motors working correctly if I press arrow or page up/down all working.
But I need reference my machine. I click to "ref all home" machine possition in mach is wery fast set to 0 but motors dont move to switches.
What I do incorrect?
Thanks co much.
Re: Ref all home dont move motors
« Reply #1 on: February 06, 2015, 06:47:05 AM »
Do you have the limit switches set up as home switches for each axis?
« Reply #2 on: February 06, 2015, 06:53:55 AM »
Limit switches must be set to the same port as homing switches if I have only one switch at axis. Correct?
« Reply #3 on: February 06, 2015, 07:09:51 AM »
If you are sharing the home and limit switches then they should be set to the same port and pin number.
You can check if you go to the diagnostics page and press each switch. The M1++ M1-- and M1Home should light up when you press the X axis switch.
Same goes for Y and Z ecept it will be M2++ etc and M3++ etc
If that is as it should be then attach your xml.
« Reply #4 on: February 06, 2015, 09:12:47 AM »
Ok I set all as you write me. Limit switches working as you write. I send my XML file.
« Reply #5 on: February 06, 2015, 01:57:40 PM »
Look at the screenshot and see if your plugin is set like that. If it is you likely need to choose one of the options below it.
I do not have that controller so I am unsure what the homing options actiually do.
