Hello Guest it is November 23, 2026, 10:13:41 AM
Author Topic: 4th axis setup in mach3  (Read 27635 times)
« on: February 03, 2015, 04:50:07 PM »
I am setting a 4th axis and for the most part i have it working just fine but for some reason the toolpath display is wrong my a axis wraps around the y axis  i am trying to have it display like a cylinder but for some reason it is displayed like a plate  it seems to cut properly ( alltho so far all i have cut is air ). I have searched for the solution and could not find it if its there please point me in the right direction thanks in advance  ;D
Re: 4th axis setup in mach3
« Reply #1 on: February 03, 2015, 05:31:37 PM »
Look IN Genconfig /toolpath and see IF you have it set for X/A.
« Reply #2 on: February 04, 2015, 05:37:06 AM »
under general config I cannot find that setting I have active plane of movement then as x-y selected although if I go to config then toolpath under rotations I have y axis selected a check mark in a rotations enabled and a check mark and use diameter for feedrate
« Reply #3 on: February 04, 2015, 01:42:55 PM »
I think you also have to set the Rotation Radius in the Settings Tab.  It's been over a year since I used it, so there may be another setting I also used.
John Champlain
« Reply #4 on: February 04, 2015, 02:03:40 PM »
In Config>Toolpath, make sure A-Rotations Enabled is selected also.
John
« Reply #5 on: February 04, 2015, 02:21:49 PM »
it is selected and the picture that you posted John is exactly what I'm trying to accomplish but for some reason it isn't that I will try to take a picture of what I see so that you can see what I'm talking about
Offline rdean
  •  94 94
« Reply #6 on: February 04, 2015, 02:49:25 PM »
On the "Settings" tab right upper corner input the "Rotational Radius" A as the radius of your part.
Ray
« Reply #7 on: February 05, 2015, 07:00:05 AM »
pics of screen
« Reply #8 on: February 05, 2015, 07:17:42 AM »
In your ToolPath Config. screen, if your A is replacing Y in the GCode, then the Axis of Rotation will be "X-Axis"
« Reply #9 on: February 05, 2015, 07:53:01 AM »
Here is a clip from the CNCWrapper help file.
(I think this is what TP was referring to earlier)
Russ
