Hello Guest it is November 24, 2026, 05:10:12 PM
Author Topic: Mach 3 to drive a motor at fixed rpm  (Read 14494 times)
« on: January 29, 2015, 05:12:12 AM »
Hi all
I need to replace the drive motor on the cnc quilting machine i built for the wife, it doesn't have enough torque at the speed I need it to run.
What I'd like to do is use another stepper motor for the sewing machine and drive it from mach 3. I'm only using 2 axis at the moment so it would be easy to use the Z (or A) axis for this.
At the moment I do a M30 motor start to turn on the machine relay at the start of the sewing action, how do I turn on say the Z axis and leave it running until I send another motor stop command at the end of the process?
Thanks Dave
Re: Mach 3 to drive a motor at fixed rpm
« Reply #1 on: January 29, 2015, 11:17:40 AM »
You can't have continuous rotation on an axis (z) BUT you can on the spindle. Set up the spindle as step direction. Then use S********* to set the RPM and M3/4 to tun it ON /OFF.
« Reply #2 on: January 29, 2015, 07:56:23 PM »
Thanks TP
Little confused on this one..... so where do we set the parameters for the stepper motor thats effectively running the spindle?
On my router I use the spindle control to turn it off and on but thats a dedicated rotation type motor.
« Reply #3 on: January 29, 2015, 08:03:47 PM »
Go to Config  /  Spindle select S/D spindle
Go to Config Ports and pins/ Motor ouputs and set up the spindle.
Go to Config/ Motor tuning and set the steps per and Vel and Accel values (make sure you save)
Shut down Mach3 and reload Mach3.
(;-0 TP
« Reply #4 on: January 29, 2015, 08:48:56 PM »
After your first reply I went back and had a look and found those settings but which axis is it connected to!
As its a stepper surely it has to be connected to one of the 4 axis drives on my Gecko 540...
« Reply #5 on: January 29, 2015, 11:09:06 PM »
Do you have an empty drive on the 540 ? If so that is where you set the Port and pins to to run the stepper for the spindle.
If you are only running 3 drives and have an empty slot add in the extra drive and mapp the signals to that slot. If all your drives are already used then add a 2nd LPT card and run the spindle drive from there.
(;-)TP
« Reply #6 on: January 29, 2015, 11:23:46 PM »
I see now.... So I've set the Step pin, Dir pin, Step port and Dir port the same as what shows for the unused Z axis which is what I'll use.
Can i set the S*** (whatever the code is) and the M03 command to auto populate from my vcarve tool path.
Do you have an example of this code?
Once again thanks for your help.
« Reply #7 on: January 30, 2015, 10:11:31 AM »
To start teh spindle and set the speed.
M3 S100
S200  (Change the spindle rpm)
M5    (Stop the spindle)
