Hello Guest it is November 19, 2026, 03:37:12 AM
Author Topic: IsMoving equivalent in Plugin?  (Read 25126 times)
Offline Tomas
  •  15 15
« on: January 28, 2015, 05:32:45 PM »
  Can someone point me to which variable/s would be the equivalent of the vbscript function IsMoving?
Tomas
Re: IsMoving equivalent in Plugin?
« Reply #1 on: February 11, 2016, 11:18:00 AM »
Hi Tomas,
I have the same problem. Had you found a solution
BR
Gerhard
Offline dz32
  •  14 14
« Reply #2 on: February 11, 2016, 06:08:27 PM »
IMach4.GetScriptDispatch() returns an
IMyScriptObject interface which contains
Function IsMoving()  As Integer
Offline Tomas
  •  15 15
« Reply #3 on: February 11, 2016, 06:59:23 PM »
  This is what I did.
Code: [Select]
int MachIdle (void)
    if ((Engine->TrajHead == Engine->TrajIndex) && MainPlanner->ExternalStill == TRUE)
        Engine->Sync = true; // Update posistions with Mach3
        return 1;
    return 0;
-Tomas
« Reply #4 on: February 12, 2016, 02:46:40 AM »
Hi
and this Engine->sync handles the ismoving() on Mach3 side ?
Gerhard
