Hello
Guest
it is
November 19, 2026, 02:04:00 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
G-Code scaling program, mm to Inches and back
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: G-Code scaling program, mm to Inches and back (Read 476317 times)
Tyler
10
Re: G-Code scaling program, mm to Inches and back
Reply #20 on:
March 17, 2008, 03:22:11 PM »
Maybe I can try reformatting the computer used for controlling the CNC machine. It seems to work with my desktop.
Thanks Graham.
Logged
W.Jansen
119
Reply #21 on:
July 22, 2008, 02:37:35 PM »
Hi Graham
Your program works perfect for me, thanks very mutch.
Just out off curiosity, what is the difference between the two versions?
Greetings:
Willem
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #22 on:
July 22, 2008, 06:01:29 PM »
Hi Willem,
thank you for your comments, the only difference is the earlier one was limited to 32000 lines of code.
Graham.
Logged
Tweakie.CNC
9,378
Super Kitty
Reply #23 on:
December 19, 2008, 08:15:36 AM »
Thanks Graham, nifty little program. I have used it a couple of times now and it was brilliant.
Regards, Tweakie.
Logged
BClemens
Reply #24 on:
February 24, 2009, 07:34:26 AM »
Thank you Graham, very useful program and also even for basic renumbering.
Bill C.
Logged
fever16
40
Reply #25 on:
February 10, 2010, 12:03:44 PM »
nice program,simple to operate.Thanks
i likes its scaling feature.and it would be much better if we could control the z depth separately.
i used custom scale as 10,so my X-Y values become 10 times larger and also made Z depth to 10 times.
Logged
BobWarfield
96
Reply #26 on:
April 05, 2010, 03:43:00 PM »
Handy utility!
Cheers,
BW
Logged
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
woodguy7777
75
Reply #27 on:
June 20, 2010, 10:12:18 AM »
[flash=200,200]I downloaded file and everything work as far as the conversion goes.
the problem i have is when i tried to run the file.
[i tried an aircut ] the file size has been reduced to a faction of the original size.
tried on two computers same problem.
enclosed is both files before and after.
thanks
paul
Logged
woodguy7777
75
Reply #28 on:
June 20, 2010, 11:05:08 AM »
My above post is a bit misleading i was sent a dxf that was made in mm i then took that file into vcarvepro
and made a cut file in mm.
then use the converted to turn it into an inch file.
an easier way to go is if i was able to change the dxf mm file into a dxf inch file.
is that possible?
Logged
Graham Waterworth
2,785
Reply #29 on:
June 20, 2010, 03:05:07 PM »
The file size has reduced by about 3600 characters this is because when you convert a mm size say 127.000 to inches you get 5. a saving of 5 characters multiply this by hundreds of conversions and the file shrinks by a large amount.
Have you found a fault in the converted file?
You can convert a DXF file in mm to inches by scaling it by 1:25.4th (0.03937) the metric cam system will think its a very small part but scale the tools too and the output will be inches, you will just need to change the G21 to G20.
Graham
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
