Hello Guest it is November 19, 2026, 02:04:01 AM
Author Topic: G-Code scaling program, mm to Inches and back  (Read 476317 times)
Re: G-Code scaling program, mm to Inches and back
« Reply #10 on: January 11, 2008, 06:08:56 PM »
Thanks Graham
works fine for me
Rob
« Reply #11 on: March 02, 2008, 08:17:34 AM »
Hi Graham,
I try you're little software but I receive a constant error "Run time error '6': Overflow. Here it is what I am doing. I have .dxf a file in inch. I import that file in Rhino then I change units in Rhino from inche's to mm. I import that file in LCam - process. Save. Try to convert back in inche's and dang that error came up. Why? What I am doing wrong? Please help me.
TIA
Gabi
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #12 on: March 02, 2008, 12:14:05 PM »
Hi Gabi,
I have not had that error reported before, post the file you are trying to convert and let me have a look.
Graham.
« Reply #13 on: March 02, 2008, 12:20:39 PM »
Hi Graham,
File it is a little large. I'll will post a archive. Please look at it and advice what do to.
Thank you
Gabi
  •  2,785 2,785
« Reply #14 on: March 02, 2008, 01:31:52 PM »
Here is the later version of the program, try this and let me know how you get on.
Graham.
« Reply #15 on: March 02, 2008, 01:38:04 PM »
Hi Graham,
That new version do the job nicely.
Thank you
Gabi
Offline Tyler
  •  10 10
« Reply #16 on: March 14, 2008, 07:41:10 PM »
Quick question, what does
"Component 'comdlg32.ocx' or one of its dependencies not correctly registered: a file is missing or invalid."
mean?
  •  2,785 2,785
« Reply #17 on: March 15, 2008, 05:22:14 AM »
You have a missing ActiveX file on your system, is it XP and up to date?
Graham.
Offline Tyler
  •  10 10
« Reply #18 on: March 17, 2008, 02:02:47 PM »
I have run the update but still receive the same error. Is there anything that could conflict with this program running?
My PC is installed in "normal PC" mode, and just about everything is changed according to the XP Optimization file on ArtSoft's website. I'm not entirely sure why neither of the versions you've posted don't work on my system.
  •  2,785 2,785
« Reply #19 on: March 17, 2008, 02:48:04 PM »
Sorry, no idea, have you tried it on another computer, it seems to work for most people.
Graham.
