Hello Guest it is November 13, 2026, 09:48:26 AM
Author Topic: x axis problem  (Read 14678 times)
x axis problem
« on: January 23, 2015, 08:07:50 PM »
I have a cnc router the name of the company I purchased it from is Industrial CNC. I have had a few problems in the past and have figured them out. The problem that I have now is with the X axis. It works fine until it moves about 3 feet left to right on the gantry. At this point The gantry stops. Always at the same point of travel. I have checked the gears, motor and slides. I have removed the motor of the x axis it turns in both directions. When the x gantry stops the DRO  numbers continue moving
Now this makes no scene to me the motor,not attached to anything, turns freely that would move the gantry to the left. If I switch direction, movement to the right, it turns freely but after several seconds , maybe longer, it stops turning. The motor is NOT attached to anything and it still stops when it turns , from what would be left to right.
I can manually move the X gantry either left or right with nothing binding in either direction. I can use the cnc and it works but I can not use the full travel of the x axis. Attached are the specs of my machine. Does anyone have an idea of what maybe happening. I have also switched the cables of the x and y axis. With the y cable controlling the x axis the problem still remains . the x gantry stops at the same point of travel.
Active Transit /Cutting speeds 900/700 IPM
Mechanical home switches
R and P on X and Y Drives, Ball Screw on z axis
Power 220
Anti Backlash
Router Features Specifications
Table Size 52" x 52"
X,Y,Z Working Area 49" x 49" x 12"
X,Y,Z, Traveling Position Accuracy +/- .002"
Frame Structure Steel
X.Y Structure Anti backlash Rack and Pinion
Z Structure Orbital Ball Screw
Max Speed 0-900 IPM
Max Working Speed 0-700 IPM
Spindle Power Motor High Frequency Conversion Water Cooled Motor
Working Mode 24000r/min
Working Voltage AC220V
Command Includes MACH controller, G Code, dxf
Interface PC
XY Working Tolerance < 0.02mm
Software Mach3, Type3 full function 3d
nywoodworker
    Vectric Apprentice
    Model of CNC Machine: Industrial CNC Router Apprentice 404
Re: x axis problem
« Reply #1 on: January 24, 2015, 04:32:07 AM »
Is a plug in used for this machine?
Post your xml file and someone will have a look.
Re: x axis problem
« Reply #2 on: January 24, 2015, 07:13:10 AM »
Re: x axis problem
« Reply #3 on: January 24, 2015, 12:49:58 PM »
Ok i am not very good at this. What xml file are you talking about.
Re: x axis problem
« Reply #4 on: January 24, 2015, 12:52:34 PM »
Have you got a soft limit set incorrectly
http://www.instructables.com/id/Setting-Soft-Limits-for-your-Industrial-CNC-Router/
I went through setting soft limits. Nothing seemed out of norm. The problem ids still their.
Re: x axis problem
« Reply #5 on: January 24, 2015, 07:11:39 PM »
You will find the xml file that you are using in the Mach3 directory. The first part of the file name is the profile name you
use / select when Mach opens. IE; router.xml
I also was thinking that there may be a soft limit setting problem.
Re: x axis problem
« Reply #6 on: January 26, 2015, 03:36:47 PM »
Is this the file you are referring to?
Re: x axis problem
« Reply #7 on: January 30, 2015, 07:24:46 AM »
Rich,
I was hoping you could take a look at the file I sent. I hope it is the one you were refering to.
