Hello Guest it is October 21, 2026, 07:54:09 AM
Author Topic: Using Mach3 Via Serial port?  (Read 18298 times)
« on: April 08, 2007, 08:27:05 AM »
Hi guys.
Silly question and I should probably try first, but...
I have a little 3 axis mill that communicates via a serial port on the computer and a parallel port on the machine. Is it possible to use Mach3 with this or do I need to go get a regular parallel cable?
Thanks!
Ken
Ken
Re: Using Mach3 Via Serial port?
« Reply #1 on: April 08, 2007, 08:46:24 AM »
Hey Ken,
      You need to get a cable. Before you do though, I have a few questions? Do you have a wiring diagram for the control cabinet? Do you know where each pin on the cabinet connector goes? I would love it if you could just unplug your old cable, load Mach, hook up another cable, and start running. It may not be that simple though.
« Reply #2 on: April 08, 2007, 08:51:37 AM »
Thanks for the quick reply Brett!
I do have the schematics on the machine....Now reading the diagrams may not be easy for me. I am very limited in my knowledge of wiring diagrams...
If anyone is willing to help in this matter, I would be much indebted and promise to dance at their next wedding :)
The pdf file is 6.7mb and I dont know if it would be appropriate to even upload here?
Thanks again!
Ken
Ken
« Reply #3 on: April 08, 2007, 09:04:56 AM »
Ken, I have sent you a personal message.
« Reply #4 on: April 09, 2007, 11:02:38 AM »
I came across this and wondered if it might be an option to convert the serial to parallel?
http://www.datapro.net/products/SXP320.html
Ken
« Reply #5 on: April 10, 2007, 08:12:37 AM »
That is not going to work :( You will have to rewire direct to the the drives :(
www.newfangledsolutions.com
www.machsupport.com
« Reply #6 on: April 10, 2007, 08:19:47 AM »
Thanks Brian.
Do you or anyone know if this controller board is any good?
http://www.hobbycnc.com/4aupc.php
I think my best option now is a new controller.
Ken
Ken
« Reply #7 on: April 10, 2007, 08:24:54 AM »
Many of the users use there stuff... I have not used them my self :(
But they should work!
www.machsupport.com
