Hello Guest it is November 13, 2026, 05:11:18 PM
Author Topic: Pokeys57E and ChargePump  (Read 12647 times)
« on: January 14, 2015, 06:54:01 PM »
Pokeys57E with firmware v3.1.45, does not stop generating charge pump signal when it lost connection. Can this be fixed in future version?
Weerasak
The CNCRoom.com, the place where Industrial Hobbyists can talk and trade!
www.cncroom.com/forum
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys57E and ChargePump
« Reply #1 on: January 15, 2015, 10:01:10 AM »
Enable the 'Pulse engine' option in Peripherals > Failsafe settings in PoKeys application set set the failsafe timeout.
« Reply #2 on: January 16, 2015, 10:27:27 AM »
Thank you for pointing it out,
Please consider to put this option in Pulse engine tab in Mach3 plugin also. Configure all options from one place, make it easy to use.
Currently, I only use PoKeys application for setting IP address, upgrading firmware and clearing all setup.
