Hello Guest it is October 05, 2026, 08:38:53 AM
Author Topic: re: Mach-3 for a lathe  (Read 63359 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: re: Mach-3 for a lathe
« Reply #10 on: April 13, 2007, 05:26:38 PM »
use the arrow keys on the keyboard
« Reply #11 on: April 13, 2007, 05:29:32 PM »
Ok that's what i thought should work the jog but still no movement from the stepper
« Reply #12 on: April 13, 2007, 05:34:14 PM »
arrow keys for jog but make sure you have the Jog enabled. You will see the button on the main screen lower middle "Jog On/Off" make sure you see the green surrounding this button, if you dont click it and you should then be able to jog. If you still cant jog press the Tab key and make sure you dont have the slow jog set to 0% or have the Jog Mode on MPG or step.
  •  2,785 2,785
« Reply #13 on: April 13, 2007, 05:37:11 PM »
On the C11G have you got the safety charge pump set to enabled JP3 pics 2-3 if so disable it. Pins 1-2
Graham.
« Reply #14 on: April 13, 2007, 05:47:40 PM »
I have enabled the jog led is on on the upper right hand of screen and jog rate is set to 100 % i hit the tab and arrow for the x axis but no movement
« Reply #15 on: April 13, 2007, 05:48:27 PM »
do the DROs move on the screen?
« Reply #16 on: April 13, 2007, 05:49:21 PM »
nope charge pump is dissabled set to 1&2
« Reply #17 on: April 13, 2007, 05:51:38 PM »
got it going not sure what i did but i am getting jog now wow thanks all you guy's i am sure i will be back with more questions.
Dennis
« Reply #18 on: April 13, 2007, 06:04:02 PM »
Any one else using the CNC4Pc board thanks to all you guy's i have my lathe running X&Z axisis but i still have one of the transistors on the board getting very hot and i am affraid to run it for long in fear of blowing the transistor any ideas as to what it could be.
Dennis
« Reply #19 on: April 16, 2007, 12:37:45 PM »
Hello again guy's
I hope you guy's don't get tired of the newbie questions and problems, well after getting the system working over the week end i turned the system on this morning and now i get no X axisis movement and the X axis movement on the screen dosn't change when i jog but the Z axis dose what did i turn on off ,going through the learning curve thanks guy's
Rg's
Dennis
