Hello Guest it is October 23, 2026, 08:03:47 PM
Author Topic: using feed per revolution  (Read 7617 times)
« on: January 12, 2015, 01:24:55 PM »
Hello Chaps.
Mach turn on o lathe
I recently fitted an inverter and now i have the ability to use css.
please tell me
1. do i use G95 as a word in the initialization string that appears in the general config box?
2. before i B*******R something would you please give me some suggested "safe" settings to start off
with. I use mm mode. please suggest a safe feed rate say f ??????
I tried f 0.05 but it doesnt do anything
3. and how go i apply the CSS in the program.
many thanks
Offline rcaffin
  •  1,073 1,073
Re: using feed per revolution
« Reply #1 on: January 19, 2015, 02:56:38 AM »
F0.05 usually means 0.05 millimetres per minute. I guess you might not see much happening!
If it is meant to be feed per rev, then maybe you have 50 microns per rev. Ditto.
« Reply #2 on: January 19, 2015, 04:00:23 AM »
sorry my typo-- should read 0.5
regards
