Hello Guest it is November 20, 2026, 02:01:58 AM
Author Topic: newfangled problem  (Read 11480 times)
Offline gorf23
  •  190 190
newfangled problem
« on: April 07, 2007, 07:01:34 AM »
I am using the newest mach3, installed on drive D, but now when i try to use the newfangled it will not look at drive D only drive C so i keep getting script error, and will not run
I have changed the script to look at drive D but when i reload its back to Drive C... anyone have a fix for this?..
Thanks gary
Re: newfangled problem
« Reply #1 on: April 07, 2007, 08:24:42 AM »
There is no fix at this time for that problem... I will send the report to Ron and see what we can do about it.
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: April 07, 2007, 10:19:14 AM »
I think you have a problem! There are several things in the VB implementation that just assume its installed in C:\Mach3. I dont think there is any way to fix it all, certainly not anything I can do from within the VB code.
What script did you change to look at Drive D: ?
Does Mach work OK for all its other functions?
Offline gorf23
  •  190 190
« Reply #3 on: April 07, 2007, 01:14:04 PM »
I seem to get the error in the file called hiddenscript, i didn't have this problem till i upgraded to the latest version of mach3...
Thanks gary
