Hello Guest it is October 20, 2026, 03:08:28 PM
Author Topic: newbe - Xylotex Z-Axis not working - please help.  (Read 10784 times)
deleteallusers
« on: April 06, 2007, 11:15:52 AM »
My Z-axis will not work. (X & Y Axis are fine) The motor is good (I tested it and the cable), The Z-Axis does lock the motor up on power up.
I'm using mach3 and I have the 425oz/in  Xylotex 3 Axis driver board.
my motor outputs are..
STEP X - Pin 3
DIR X - Pin 2
STEP Y - Pin 5
DIR Y - Pin 4
These work fine, but I can't get the Z to work, what should I do ?
could it be some dumb pins like 22 & 23 ???
Thanks for the help
Re: newbe - Xylotex Z-Axis not working - please help.
« Reply #1 on: April 06, 2007, 12:08:33 PM »
What pins are your Z axis, I would set it up for pins 6 & 7.
deleteallusers
« Reply #2 on: April 06, 2007, 01:00:55 PM »
Problem fixed ! It was a chepo db25 cable. I had asked the electronics store for
a good cable but they sold me a chepo.
Thanks everyone for all the help !    :-*
« Reply #3 on: April 06, 2007, 01:19:23 PM »
