Hello Guest it is November 10, 2026, 01:54:53 AM
Author Topic: how to trigger action by reading g function  (Read 12641 times)
« on: January 07, 2015, 01:39:07 PM »
hi all
i hope to find an answer but may be the question is wrong , i would like to keep the spindle on while the last g function is g1 and turn it off while the last g function is g0 is it possible to make mach3 to read the g-code and identify the functions in it and trigger actions by it????????
please help
 :o
Offline TPS
  •  2,627 2,627
Re: how to trigger action by reading g function
« Reply #1 on: January 07, 2015, 02:49:35 PM »
hi,
hi all
please help
 :o
put a M5 between the last G1 and the first  G0, done.
« Reply #2 on: January 07, 2015, 03:39:14 PM »
pls explain more that i need to learn
« Reply #3 on: January 07, 2015, 03:41:34 PM »
and how to do it by adding a button or macro
that i need to do it so many times and not to do it manually
Offline TPS
  •  2,627 2,627
« Reply #4 on: January 08, 2015, 06:24:56 AM »
normaly your cam software is doing that for you.
for the moment i do not understand for what you
want to use this.
Thomas
« Reply #5 on: January 08, 2015, 12:22:45 PM »
i;m warking on a new application acts like plasma so tourch on when cutting the drawing and tourch off while getting safe z up/dowen and jug movement .
if you please refer to a cam softwaer that makes this ( i;m warking with artcam if it makes that please refer )
and it's important to do this by mach3 user's interface
« Reply #6 on: January 08, 2015, 01:41:36 PM »
That is basically HOW Torchmate operates. In G0 mode it is torch OFF and everything else is Torch ON.  No real advantage over doing it with M3/5 through the CAM. Does make it harder to read the code from the operators perspective.
What you are looking to do would HAVE to be done through a plugin or internal to Mach3.
To do it from CAM . ALL cams tend to operate that way.
« Reply #7 on: January 08, 2015, 01:45:43 PM »
could it be made by macro and pls refer to the plug in thead if it exists
« Reply #8 on: January 08, 2015, 02:06:26 PM »
You would have to create a new PLugin to do it this way as there are NO current plugins to do this.
