Hello Guest it is October 24, 2026, 03:31:51 PM
Author Topic: Mach3 + CS LAB Ethernet 32 or 64 Bit??  (Read 15312 times)
« on: January 05, 2015, 02:12:43 PM »
Mach3 writes for 32 Bit with parallel port
But> Mach3 + CS LAB Ethernet with PC windows7 >> 32 or 64 bit ??
Can Mach3 than perfect work on 64 Bit?
Re: Mach3 + CS LAB Ethernet 32 or 64 Bit??
« Reply #1 on: January 05, 2015, 05:09:30 PM »
Mach itself will run fine on a 64Bit OS, it is just the parallel port driver that requires a 32bit OS.
So you can use whatever you want.
« Reply #2 on: January 06, 2015, 03:37:37 AM »
I read on some topics that 64 Bit problems would be with the VB scripts ... true or false ??
I would obviously like to go for 64 bit
grtz
« Reply #3 on: January 06, 2015, 01:19:14 PM »
Not heard of VB issues with 64bit OS and I know that is what CS-Lab use on their machines. I only have Xp on my machines so cant say from experience.
« Reply #4 on: January 06, 2015, 04:56:22 PM »
ok thx Hood
I'm using win7 64bit CS LAB. I hope to be operational within two weeks. Programming much Modbus PLC for toolchanger
grtz
« Reply #5 on: January 07, 2015, 05:53:00 AM »
Hi FredMazak,
I'm running a Csmio ip-s controller on a 64 bit windows 7, and both Mach3 and 4 run fine. I have several VB scripts running without any problems on Mach 3. Mach 4 has a small glitch with m3/m4 not starting the spindle. But the spindle on/off button works ok. M3/M4 sends the 0-10v to drive but it doesn't activate the output.
Hope this helps.
Alan
