Hello Guest it is October 25, 2026, 12:31:03 AM
Author Topic: New to mach3 and cnc/ not cutting in cm  (Read 13786 times)
« on: January 04, 2015, 10:06:43 PM »
I have a 3axis cnc with mach 3  and Routcad software. But every time I draw something in cm in the Routcad then load the gcode in mach3 it starts to cut in a larger  scale.  I've checked everything I know of and it's all showing metric. Any help would be great
Re: New to mach3 and cnc/ not cutting in cm
« Reply #1 on: January 04, 2015, 11:04:15 PM »
Change your units to mm.
« Reply #2 on: January 05, 2015, 09:41:50 AM »
Thanks for the reply, when I set up the machine w mach I used the mm , and when I go through mach and look around. The mm button is on.
So according to mach it's in mm.  My Routcad software uses cm . . Not sure what els to try.
Tom
« Reply #3 on: January 05, 2015, 11:16:43 AM »
Consult your Routcad manual. I would assume that you can select different units.
If MM is not available you could generate code in inches and use a converter to convert the code to MM.
You could also scale in Mach, have a look in the Mach manual for info.
BTW....never heard of Routcad  ???
« Reply #4 on: January 05, 2015, 08:49:10 PM »
Well I changed my steps from 640 to 320  and now it cuts perfect mm . But now when I'm cutting  a program  it seems to cut the holes good but then when it's time to cut out the object it starts half way up the material.
« Reply #5 on: January 06, 2015, 06:11:17 AM »
You need to define how you want to machine something in CAM.  Know nothing about your software.
« Reply #6 on: January 06, 2015, 05:01:17 PM »
I have a similar problem; I am configured in inches. the X & Y cut fine, but the Z cuts in mm's.
« Reply #7 on: January 06, 2015, 07:16:43 PM »
mikesbeehives,
If the code is correctly generated in inches only, ie; no code to change the z , and the axis steps are correct for inches , and Mach config units are inches and no scaling, then Mach will generate the correct pulses for the move.
Maybe it's your external device or plug-in that is goofy. ???
« Reply #8 on: January 06, 2015, 07:31:36 PM »
If I zero everything after jogging to a max and then jog to the opposite Max., the x & Y dro are correct. The z dro is 54.2, when it has actually only moved 4".
