Hello Guest it is October 11, 2026, 11:02:18 PM
Author Topic: Why LazyCam Do not Generate M25 Code!! PLS HELP!  (Read 8984 times)
« on: January 03, 2015, 06:58:26 AM »
How I can configure my lazycam to generate M25 code when the z axis will move down? Because in my M25 file I have written a vb scripter for the probe !!
Re: Why LazyCam Do not Generate M25 Code!! PLS HELP!
« Reply #1 on: January 03, 2015, 04:37:32 PM »
Manualy edit the code to add the M25 once it is posted to Mach.
I am not aware of any Post Processor (pp)for LC that you can modify. The posting options allows selection of a pp,
Your on your owne for this one..........
Modified ....SEE NEXT REPLY
« Last Edit: January 04, 2015, 08:31:55 AM by RICH »
« Reply #2 on: January 04, 2015, 08:29:48 AM »
wakedabed,
I have attached a file found on the FTP site. The file may actualy be located where you installed LazyCam.
Your on your own for creating a pst. You can use the Screen Setup>Posting Options and click the Set Post Processor
to select what pst you want to default to.
I have never tried using the pst and haven't the foggiest idea of what the affects will be.
Don't even know if it works! ??? :D
Hack away............ ;)
« Last Edit: January 04, 2015, 08:35:05 AM by RICH »
