Hello Guest it is October 20, 2026, 11:53:06 PM
Author Topic: License Installing problem  (Read 39062 times)
Re: License Installing problem
« Reply #10 on: June 21, 2016, 02:15:23 AM »
Having same problem as reported by cliffh in 2007 - will load on one computer and not another. Must be a simple answer to this problem, surely?
« Reply #11 on: June 25, 2016, 07:39:15 PM »
After receiving 20855 license for Mach3, copied to Mach3 directory OK, but still shows as demo, no name, and limited gcode?  See attached license.
I appreciate the help.
Edit - License file removed for security reasons - Tweakie.
« Last Edit: June 26, 2016, 12:34:41 AM by Tweakie.CNC »
  •  9,374 9,374
« Reply #12 on: June 26, 2016, 12:44:40 AM »
Unzip the license file that was sent to you.
Open the folder mach3.
Open the folder JOHN……….
Copy the file Mach1Lic.dat into your C: Mach3 folder.
On restarting Mach3 you will have Licensed To: John………... and the demo restrictions removed.
« Reply #13 on: June 26, 2016, 07:43:04 PM »
Half way there...  there was no folder named John........ So I pasted Mach1Lic.dat into Mach3 Directory.  It ran all gcodes without limits, but when I
looked at license under help, the name was not mine.   It was  MaoAA Dtonas?
  •  9,374 9,374
« Reply #14 on: June 27, 2016, 01:13:47 AM »
The license file you previously posted here was the correct file, the one you have just installed on your PC is not the correct file.
I have tested your license file and it is working correctly and displaying your name.
Go back to your original email from Licensing to get the correct zip file, unzip it and copy that Mach1Lic.dat into your Mach3 folder.
« Reply #15 on: June 27, 2016, 06:14:57 AM »
Thanks again, I'll give it a try today.
« Reply #16 on: June 28, 2016, 08:26:10 PM »
Thanks Tweakie,  that solved that problem.
  •  9,374 9,374
« Reply #17 on: June 29, 2016, 12:24:33 AM »
I am pleased that you have it sorted.
