Hello Guest it is October 23, 2026, 05:51:17 PM
Author Topic: How to switch incremental or absolute distance mode in Mach3?  (Read 15975 times)
« on: December 26, 2014, 09:37:42 PM »
Hello,
I'm a newbie on the Mach3, and I have a basic problem.
Thanks reply.
  •  9,374 9,374
Re: How to switch incremental or absolute distance mode in Mach3?
« Reply #1 on: December 27, 2014, 12:50:46 AM »
The Gcodes;  G90 switches to Absolute and G91 to Incremental moves.
« Reply #2 on: December 27, 2014, 01:22:48 AM »
Thanks, Tweakie.
The only way is G-code?
Is there any hotkey or setting in Mach3 which I can switch them?
Thank you.
  •  9,374 9,374
« Reply #3 on: December 27, 2014, 03:51:48 AM »
Within Mach3;  Config. / General Config. set "Distance Mode" Absolute / Incremental.
I think you would have to add a screen button (or two) with CB code to toggle between the two states using a defined hotkey / keys.
« Reply #4 on: December 27, 2014, 06:26:34 AM »
Thanks, Tweakie.
I'll try your solution.
Thank you very much!
