Hello Guest it is October 20, 2026, 08:56:47 PM
Author Topic: Xylotex help needed - newbe  (Read 14017 times)
deleteallusers
« on: April 04, 2007, 01:41:56 PM »
I'm using mach3
I've just setup my Xylotex 3-Axis step motor driver (I'm just trying to get the one Y axis motor moving right now)
The motor seem to be locking up on power up.
I've double checked the step/dir pins as follows
STEP X - Pin 2
DIR X - Pin 3
STEP Y - Pin 4
DIR Y - Pin 5
STEP Z - Pin 6
DIR Z - Pin 7
I have one LPT port on my computer and my step/dir port is set to 1 in mach 3
I really don't know anything as I'm new, here a senerio...
I click the JOG Y+  nothing happens
> I click the JOG Y-  nothing happens
> I click the JOG Y+  It may be moving 1.8deg (1 step)
> I click the JOG Y+  nothing happens etc...
I'm able to reverse this one step movment from Y+ to Y- if I enable the Dir LowActive, however
STEP should be ACTIVE HIGH, and the DIR must be stable 200ns before & after the rising edge
of the step signal. It should also be valid for 2us or more, I know my port address is correct.
I'm really new at this, has anyons got some config files I could copy into the mach 3 dir.
Or advise would be wonderfull.
Thank you everyone, I really need help on this.
mark@landmarku.com
Re: Xylotex help needed - newbe
« Reply #1 on: April 04, 2007, 03:03:37 PM »
Mark,
    Hit your tab key and see if you are in Cont. mode.
deleteallusers
« Reply #2 on: April 04, 2007, 03:44:42 PM »
Yes I am in Cont mode..
It seems to only jog 1 step when I press the Y-, only after I have just pressed the Y+ (which does not step)
I'm lost :(
Here's my motor outputs settings
« Last Edit: April 04, 2007, 03:59:07 PM by deleteallusers »
« Reply #3 on: April 04, 2007, 05:12:59 PM »
Can you post your XML for us to look at?
deleteallusers
« Reply #4 on: April 04, 2007, 07:06:19 PM »
Yes I will first thing tomorrow from work.
But It's just what was installed and ceated by mach3, I dont know how to use that file.
« Reply #5 on: April 04, 2007, 08:55:00 PM »
sounds like you need to revers your step and direction pin (I have done that :) )
www.newfangledsolutions.com
www.machsupport.com
deleteallusers
« Reply #6 on: April 06, 2007, 08:43:49 AM »
THANKS ! EVERYONE !
@ Brian Barker, Yep, that's what it was.
Thanks again. I think I'm on my way.
