Hello Guest it is September 05, 2026, 12:29:03 PM
Author Topic: Driver Fault  (Read 9012 times)
Driver Fault
« on: April 04, 2007, 12:51:53 PM »
I don't see a standard input to read a driver fault.
How do folks out there read this?  I'm adding it as an E-stop input, but that's not quite what I want.
Re: Driver Fault
« Reply #1 on: April 04, 2007, 08:45:36 PM »
We set them up as an Estop... but if you wanted you could do the following:
   If (OEMTrig3 and getLED(0)) Then
       doButton(21)
       MsgBox("Drive crapped out")
       Exit Sub
   end if
You would put this code in the macro pump
Brian
www.newfangledsolutions.com
www.machsupport.com
