Hello Guest it is November 13, 2026, 10:32:55 AM
Author Topic: Additional Spindle control  (Read 11191 times)
« on: December 15, 2014, 12:13:57 PM »
I have set up my spindle control in mach 3 and I can turn it on and off by pushing the spindle button on the Mach 3 screen.  I would also like to add another safety control to the spindle via a selector switch connected to a input.  This switch would lock out the spindle control.  I have assigned it to an input but don't know how to program it to disable the spindle output.  Can anyone help me out?
Re: Additional Spindle control
« Reply #1 on: December 16, 2014, 10:54:04 AM »
hi i can help you please tell me exact wat you need
« Reply #2 on: December 16, 2014, 10:55:25 AM »
do you have internet so i can mange properly
« Reply #3 on: December 16, 2014, 12:14:39 PM »
Yes, I do .  What I am trying to do is to put an active low signal on input #1 (or any other input that will work) which will lock out the spindle relay connected to output #1
« Reply #4 on: December 16, 2014, 12:28:30 PM »
Your basically adding a software control as a safety for another software control. Imo, you should really have a mechanical switch to lockout your spindle, if it's purpose is a safety switch.
