Hello Guest it is September 23, 2026, 03:53:22 AM
Author Topic: Here is a way to pass a Variable number of Params to a Lua function  (Read 38855 times)
Here is a way to pass a Variable number of Params to a Lua function.
function VariableParamFunc(...)
   local p1 = 0;
        local p2 = 0;
        local p3 = 0;
        local mInst = 0;
        local inst = mc.mcGetInstance(mInst);
   p1, p2, p3 = select(1, ...);--this means start with the 1st param, and get
        --all that is passed, in this case a max of three are passed, so p1-3
       --receives them.
        if p1 == nil then p1 = "nil"; end
        if p2 == nil then p2 = "nil"; end
        if p3 == nil then p3 = "nil"; end
   mc.mcCntlSetLastError(  inst,
                                           "p1 = " .. tostring(p1)..
                                           " p2 = ".. tostring(p2)..
                                           " p3 = ".. tostring(p3));
end
if (mc.mcInEditor() == 1) then
    VariableParamFunc();
    VariableParamFunc(2,3,4);
end
--You can pass as many params as you want, by putting in the function
--variables that get them via the order them come in at.
--this example handles three.
The website screws up the formatting, so the file is attached.
Scott
« Last Edit: December 02, 2014, 01:55:27 PM by poppabear »
Re: Here is a way to pass a Variable number of Params to a Lua function
« Reply #1 on: December 02, 2014, 06:04:44 PM »
Hya Scott, Can your method be used with a Mcodes  such as M701 . If so can you give an example (;-).
« Reply #2 on: December 02, 2014, 08:38:56 PM »
HIYA SCott, I think I found the answer to that question. In Mach4 you cannot use the ( ) for anything other than comments in Gcode. AND mach4 woul dhave to be modified to anything else.
Thanks , (;-) TP
« Reply #3 on: December 03, 2014, 06:14:15 AM »
Yes, it is only for using inside a script.
It cannot be used (at this time), in the MDI or G-Code,
but....  you can pass local #vars to a User Macro in the MDI or G-Code.
Scott
