Hello Guest it is November 10, 2026, 01:53:01 AM
Author Topic: Problem with probing routines - unexpected movement of G31 routine  (Read 19430 times)
Hello,
Im trying to implement some probing features but when probing X or Y,  the probing head also moves in Z direction when I use G31X (no idea what triggers this behaviour)
example Code:
Code: [Select]
If IsOutputActive(Output15) Then
SetOEMDRO(47, 0)
SetOEMDRO(48, 0)
SetOEMDRO(49, 0)
PosX=GetOEMDRO(83)
PosY=GetOEMDRO(84)
'X+ Probing routine
Position = GetOEMDRO(83)
Code "G31 X" & (Position + 20) & "F850"
While IsMoving()
Wend
Position = GetVar(2000) 'real x probing point
Code "G01 G53 X" & (Position - 0.75) & "F500"
While IsMoving()
Wend
Code "G31X" & (Position + 1) & "F40"
While IsMoving()
Wend
Result= Position-(GetOEMDRO(1325)/(2)) + GetOEMDRO(1310)
It would crash into the table because it moves both axis.
Anybody here who had this problem before :/?
Max
Re: Problem with probing routines - unexpected movement of G31 routine
« Reply #1 on: November 28, 2014, 01:12:03 PM »
Try shutting down the PC stone cold dead then power it back up and retry the sequence.
Also try a G31 from the MDI and see if the problem is there also.
« Reply #2 on: December 01, 2014, 09:57:41 AM »
I tried it again after some restarts and also from the MDI line.
It seems to work now for the time being. But I really don't want to slow down my mill to 10% everytime so I can e-stop it before it crashes with the probe.
As long as this error isnt repeatable its pretty useless :/
Im using the Ethernet Smoothstepper.. maybe thats part of the problem.
PS: I didn't know about the 2000-2005 variables since last week so I always used this fast and slow approach routine.
When using probe tripping variables, is it necessary to approach with a slow feedrate? I guess it jsut depends on the update-rate of the digital inputs? I couldn't really find any relationship between feedrate and repeatability of the results.
« Reply #3 on: December 01, 2014, 10:55:10 AM »
The G31 reacts FASTER than any motion you can produce in Mach3.
BUT the Faster you go the more overshot you will see as Mach3 Has to do a controlled stop abiding to the Config of the Axis for VEL Accel.
NOW does the G31 ever hicup(;-) In Straight Gcode applications NOPE.
IN Macros mixed with CB and Gcode YEP
« Reply #4 on: December 02, 2014, 08:16:19 AM »
But is the overshoot really a problem?
The 2000 variables are saved directly on the trigger point I hope?
Or do you mean because overshoot may be unhealthy for the probes?
« Reply #5 on: December 02, 2014, 11:41:33 AM »
It will depend on what your acell settings are and how FAST you are moving. IF it overshoots too far it could damage the probe if it is against a hard stop.
The trip point values are stored in the 2000 variables as you noted so that is not a problem.
« Reply #6 on: December 09, 2014, 11:27:59 AM »
Hm ok i really can't find any consistency here.
I have no Idea what triggers this error.. It could also be the weather or star constellation.
I tried to calibrate my probe again after a new pc start and did nothing in mach3 but mill a simple reference surface.
Is this a known problem? Maybe for smooth-stepper users? I guess I can't be the only one with this problem
« Last Edit: December 09, 2014, 11:38:40 AM by SteelWolf »
« Reply #7 on: December 12, 2014, 12:01:13 PM »
Are you running a smoothstepper or LPT port??
« Reply #8 on: December 17, 2014, 06:58:27 AM »
Ethernet Smoothstepper  :P
« Reply #9 on: December 17, 2014, 06:08:54 PM »
OK with the SS Mach3 does NOT do the motion for probing it is controlled from the SS. Check with Greg over at Warp9.
