Hello Guest it is November 13, 2026, 07:37:45 AM
Author Topic: Is there a G-code that can pause Mach 3 while running a program?  (Read 16979 times)
Offline Hobie
  •  12 12
« on: November 25, 2014, 10:48:36 PM »
I'm using a Sherline sensitive drilling tool to drill some small holes (lots of 0.022" dia holes). I can extract the drill hole location into a separate G-code file.  I need to pause the controller between each hole while I manually plunge the drill.  I did a search but was unable to find anything on point.  I hope that doesn't mean there is no way to pause a running program?
TIA,
Ken
Re: Is there a G-code that can pause Mach 3 while running a program?
« Reply #1 on: November 25, 2014, 11:06:38 PM »
M0  or M1   pauses the Gcode file and waits on a Cycle start to resume
code
code
code
M1
code
code
etc
Offline Hobie
  •  12 12
« Reply #2 on: November 25, 2014, 11:55:28 PM »
M0 - program stop.  I guess that will work.  I'll have to check it in the morning.  I didn't think would work as I was looking for something lick a pause command.
Thanks.
« Reply #3 on: November 26, 2014, 08:45:15 AM »
THAT IS the pause command for Gcode
Offline Hobie
  •  12 12
« Reply #4 on: November 26, 2014, 10:47:58 AM »
It may be a pause command to you but from my thinking it's a stop command.  Any way it works like you stated and I'm on my way to drilling 48 tiny holes.  Just hit the button and push down on the plunger, on the next hole.  Step and repeat.
Ken
