Hello Guest it is November 13, 2026, 05:19:42 PM
Author Topic: Mach3 v R3.043.066 & Pokey 55 software V2.1.15  (Read 21535 times)
« on: November 24, 2014, 05:30:41 PM »
Hi I bought a 2nd hand lathe Emco Turn 140 which is a 2 year ago retrofitted
with Mach3 (version R3.042.040) and an I / O board Pokey55 software Pokey 55
software V2.1.15
Perhaps the / transport (der) shaken loose some electrical wires (fixed
everything put back) and since then there are strange things with the MPG
which is controlled by the Pokey55 ..
Now I thought Mach3 to update to the latest version R3.043.066 >> but it
works with the old existing Pokey 55 software V2.1.15> if so should be
rewritten the scripts for the Toolchanger VB ???
Please your experience / advice
thx
Offline NeoTO
  •  504 504
    • PoLabs
Re: Mach3 v R3.043.066 & Pokey 55 software V2.1.15
« Reply #1 on: November 25, 2014, 02:00:25 PM »
Based on the old version of the original Mach3, I assume that it was using the old plugin for Mach3 (written by Scott). Do you have any screenshots of the plugin settings?
« Reply #2 on: November 26, 2014, 02:05:04 AM »
Screen 1
« Last Edit: November 26, 2014, 02:07:05 AM by FredMazak »
« Reply #3 on: November 26, 2014, 02:06:09 AM »
screen 2
« Reply #4 on: November 26, 2014, 02:07:44 AM »
screen 3
« Reply #5 on: November 26, 2014, 02:08:24 AM »
screen 4
« Reply #6 on: November 26, 2014, 02:14:51 AM »
currently doing the MPG wheel again, but not its tool changer ...
grtz
Frederik
« Reply #7 on: November 26, 2014, 02:28:16 AM »
would a pokey 57E and PoKeyCNCaddon want to put in place of pokey55 since there are problems with the Pokey55 + I need additional inputs for safety proxy per axs
Can you help me with diagrams and script for MPG and toolchanger SAUTER Emco Turn 140
Here I would also Mach3 want to upgrade to the latest version
Thank you in advance
Kind regards
