Hello Guest it is October 23, 2026, 10:47:01 PM
Author Topic: Does Mach 3 generate 3D from bitmaps?  (Read 10347 times)
« on: April 02, 2007, 06:35:51 PM »
I'm been directed to Mach since it apparently has the ability to generate 3D files from bitmap images. Can someone direct me to the proper area in Mach for this info.
Joe
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Does Mach 3 generate 3D from bitmaps?
« Reply #1 on: April 02, 2007, 09:59:35 PM »
I've been demoing the new Lazing Cam and it remarkable!!!!
Lazy Cam is becoming a strong competitor in the industry. I have to say that there is much I don’t know about Lazy Cam, but I have worked with the bitmap importing and it works great!!!
Make sure to adjust the step over and such. See attachments
If you have any troubles let me know... Lazy cam in located in the Mach folder.
« Reply #2 on: April 03, 2007, 04:24:10 AM »
Zealous,
Thanks very much for the information. I appreciate your directions.
The image you posted was a very attaractive half tone and should route very clean. Have you given it at a go on the CNC?
Can't wait to give this a go.
Please let me know how you do with this venture.
J.
www.normansignco.com
