Hello Guest it is November 21, 2026, 05:38:24 PM
Author Topic: Mulitipass button  (Read 13102 times)
Mulitipass button
« on: November 23, 2014, 01:22:22 PM »
Hello, it's me again...
While watching the tutorials I see a Multipass button that doesn't show up in the Program run screen. Am I missing some thing or has this been taken out?
 I finally figure my CAD out and have designed a project that need the multipass option.
Thanks.........gldfshrdr
Re: Mulitipass button
« Reply #1 on: November 23, 2014, 01:36:24 PM »
It's been replaced by the multi pass wizard.
« Reply #2 on: November 23, 2014, 01:54:18 PM »
Thanks. This should be fun to figure out.
« Reply #3 on: November 23, 2014, 05:40:21 PM »
How are you creating your g-code so that you need to use the multi pass wizard?
If you need to convert your code to multipass on a regular basis, you need to re-think the way you're creating your code.
« Reply #4 on: November 23, 2014, 06:46:54 PM »
I do have F-engrave that converts bitmaps to G code. I did not use it in this case. I'm not sure it will allow multipass but I haven't tried it either.
Thanks   .....gldfshrdr
« Reply #5 on: November 23, 2014, 07:43:54 PM »
The Multipass wizard works great. The progress screen never showed any progress. But when I checked the file it was there, loaded and ran the simulation just fine.
Thanks......gldfshrdr
« Reply #6 on: November 23, 2014, 08:34:16 PM »
I beleive it IS possible to resurect the old multipass function if you really needed it. Instead of rewriting the Gcode it just loops it with a M30 and Z inhibit.
Just a thought, (;-) TP
