Hello Guest it is October 24, 2026, 04:59:09 AM
Author Topic: acpi vs standard pc  (Read 14430 times)
Offline comet
  •  338 338
acpi vs standard pc
« on: April 02, 2007, 04:36:59 PM »
  could someone please explain the diferance between acpi and standard pc mode,
and how that relates to running mach3?
    cheers
     Tony
Re: acpi vs standard pc
« Reply #1 on: April 02, 2007, 04:57:11 PM »
This is what I understand it to be
ACPI basically means windows shares IRQs for hardware and manages them when nesescary, usually this is ok but occasionally it can cause problems, it is I think dependant on motherboard design. Standard PC you can assign the IRQs manually.
« Reply #2 on: April 02, 2007, 09:08:12 PM »
Has anyone tried the REALTIME function available in Task Manager??  I stumbled across the function by right clicking on Mach3 in the Process Manager and a drop down appears where you can set the priority to Realtime.  You also get a message indicating some bad things can happen.  BUT, if this stops MS from interrupting Mach3 's functions during a prolonged run .........
JWI
Offline comet
  •  338 338
« Reply #3 on: April 04, 2007, 03:27:36 PM »
Thats interesting the realtime thing,I just tried it and I'm sure I got a cleaner driver test.
prehaps you should post that as a question to get a better response.
   Tony
« Reply #4 on: April 04, 2007, 03:36:24 PM »
Thanks Comet,
     Any test you guys can do and report on would be great. That is what makes this forum so great. Lots of people sharing what they have learned. ;D
Offline patrick71100
  •  14 14
  • HURCO
« Reply #5 on: April 08, 2007, 09:29:37 PM »
I AM A GAMER AND IF YOU DONT USE STANDARD PC DRIVER FOR PROC, INTERRUPTS
VIDEO CARD PIPELINE AND COMP, WONT RUN GAMES WORTH A DARN
