Hello Guest it is November 26, 2026, 06:00:17 PM
Author Topic: Mill Wizard Simulation  (Read 18746 times)
« on: November 21, 2014, 03:14:39 AM »
HIYA RON , How about adding in a motion simulator for the Mill Wizard.
Re: Mill Wizard Simulation
« Reply #1 on: November 21, 2014, 06:04:29 AM »
Interesting idea. We will have it hooked into Mach4, so you can directly load the file into M4. You w il also be able to enter values into the grid for the polyline, so you can do a CopyCat like function- move the M4 axis around, just click a button and the X,Y values will load into the grid.
Lots more coming, just got to work in my retired time frames, and when I can get some time from Brian for the harder parts.
« Reply #2 on: November 21, 2014, 10:27:07 AM »
Being that the WISS is independant from M4 you cannot depend on having M4 available. An internal simulator would be best.
Just an opinion, I never found the Grid to be very useful.  Direct keyboard input is the way to go for numerical values.  Normally you have a print that is INCREMETAL in nature
G1 XxYx   is very easy and does NOT require a mouse.
One other thing could you make it NON mouse friendly (hotkeys or Tab order)
