Hello Guest it is November 21, 2026, 03:43:05 PM
Author Topic: How to setup the parameters in VFD for spindle  (Read 12449 times)
« on: November 20, 2014, 02:49:22 PM »
hello
i have a question and i can't find the answer for it
i have a LS(LG)  VFD Korean one     it's 1.5KW 2HP
AND the spindle unfortunately 2.2KW  3HP   so all i am asking can i run the spindle according to the VFD max output i mean could i use the VFD to run the spindle with the specs of the 1.5KW spindle coz i don't not neeed all the 3 horse power inust want to rin the spindle like it's 1.5 KW ones?
is it possible ?
Re: How to setup the parameters in VFD for spindle
« Reply #1 on: November 20, 2014, 08:56:52 PM »
A 1.5kw VFD will run a 2.2kw motor although the motor won't develop full torque and HP if needed.
« Reply #2 on: November 21, 2014, 01:18:11 AM »
yeah i know :) i will not get the full toque  or the HP but all what i am askink can i get the HP and Torque for the 1.5KW spindle ?
« Reply #3 on: November 21, 2014, 01:43:01 PM »
Chances are you won't need the full 1.5kw VFD output (approx 6 amps@400hz,3ph,230v) unless you are taking heavy cuts with a large cutter and high feed rates so the motor kw or HP difference between 1.5kw and 2.2kw is a moot point. The worst thing that will happen is stalling the motor. You can watch the motor amps on the VFD display.  Also be aware the all cheap Chinese VFD's operates in V/F (volts to frequency) mode which means as the output frequency is reduced, i.e speed control, the output voltage is reduced which affects motor torque. High quality industrial VFD's such as Toshiba and Siemens can run in vector mode to eliminate this problem.
« Reply #4 on: November 21, 2014, 01:49:13 PM »
thanks geh7552 :) i will buy new VFD tomorrow :) and thanks for the advice the motr did not develop full HP  i got yar adivce and am just about to buy new VFD :D
thanks for helping :)
« Reply #5 on: November 21, 2014, 04:30:50 PM »
I would try the 1.5kw VFD first before spending money on a new 2.2kw drive. Unless you are planning to run the motor at 100% output under a heavy load you probably won't see any difference between the two drives.
