Hello Guest it is November 13, 2026, 08:04:57 PM
Author Topic: Should i buyr mach 3 or 4 beta now?  (Read 10005 times)
« on: November 19, 2014, 09:37:13 AM »
Should i buy the mach 3  now or wait for 4?
What is actually the difference?
It says that 3 will be discontinued?
My conversion is almost finished.
Thanks, john
Re: Should i buyr mach 3 or 4 beta now?
« Reply #1 on: November 19, 2014, 10:29:12 AM »
Mach4 is a completely new control, written from the ground up. The biggest issue is that I don't think anyone really knows how close it  to being "finished".
Are you using a parallel port, or motion controller? There are very few Mach4 motion controller plugins available right now.
« Reply #2 on: November 19, 2014, 10:39:15 AM »
I'm using the Ethernet smooth stepper for my controller.
« Reply #3 on: November 19, 2014, 10:50:18 AM »
There currently is no Mach4 plugin available for the ESS.
If you want to use your machine right away, Mach3 is probably your best option right now.
